Need help identifying capacitors please.
My daughters Nintendo OLED stopped charging. It would charge slightly with a movement of the usb c cord. Thought that this could be related to a loose charging port. I decided to try a hand in micro-soldering. Was able to remove and replace, but the hands free station I had bought was a bit rough on the board. The clips were strong and the teeth had removed a few capacitors. I have tried to look up and somewhat learn about them, the size, the voltage, and mF power. I need help so I can try and replace these pieces, please. I have tried to circle and number the areas in question on the photo. All help and info is welcome please.
Это хороший вопрос?
Счет 0
Добавить комментарий
