Выпущена в ноябре 1998 года, идентифицируется по номеру модели HKT-3020.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
Это хороший вопрос?
Счет 0
8 Комментариев
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
Добавление изображений к существующему вопросу
Thank you.
из
Can I upload video? pictures won't help
из
Yes you can!
Using Media
Thank you
из
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
из
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
из
Показать ещё 3 комментариев
Добавить комментарий
1 ответ
Выбранное решение
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
Alright. Then it is normal behaviour. Thanks for sharing!
из
Sorry for the delay thank you
из
No problem at all! Have a great day :)!
из
Добавьте свой ответ
Christopher D буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 37
За все время: 217
