How to remove the motor casing?
How to remove the motor casing - now broken - and install a new casing?
Это хороший вопрос?
Это хороший вопрос?
Disassembling the trimmer head on the Ryobi P2008 (2018) is a straightforward task. First, remove the battery. To access the spool or remove the head, align the notch on the trimmer head with the small hole on the gear case, insert a locking pin or a small screwdriver to lock the shaft, and turn the head clockwise (it has a reverse thread).
Step-by-Step Breakdown
1. Removing the Spool Cover (For quick string replacement)
You do not need to unscrew the entire head just to reload the trimmer line.
2. Removing the Trimmer Head (For replacement or clearing jams)
If you need to replace the entire bump head assembly, you will need to unthread it from the drive shaft.
3. Disassembling the Upper Components (Motor Cover & Housing)
If you are doing deeper repairs like replacing the motor, handle, or wiring, you will need to access the upper housing.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 15
За последние 30 дней: 92
За всё время: 293
