I have an E1 error
Whats an E1 error. What do I need to correct to fix this issue?
Это хороший вопрос?
Это хороший вопрос?
The E1 error code on a DeLonghi portable air conditioner typically indicates a probe or temperature sensor failure. It means the internal thermostat (or thermistor) that monitors the room temperature or evaporator coils is shorted, disconnected, or malfunctioning.
Step-by-Step Troubleshooting
Before purchasing replacement parts or calling for repairs, perform these basic troubleshooting steps:
1. Perform a Hard Reset
Sometimes the sensor registers a glitch and simply needs a fresh start.
2. Check and Clean the Filters
A heavily clogged filter limits airflow and can cause the system to freeze or overheat, triggering sensor errors.
3. Fully Drain the Unit
If the internal condensation tray is completely full, it can trip float switches or error codes.
4. Check for Wiring Issues
If you are comfortable opening the portable AC housing (and the unit is unplugged), you can check if the sensor wires came loose from the circuit board.
For tips on accessing and fixing loose sensors or resetting your system:
How to Reset DeLonghi Portable Air Conditioner – Power Cycle & Error Code Reset Guide
Next Steps
If the error code remains after these steps, the internal temperature sensor (thermistor) or the control board is likely defective and needs to be replaced.
Depending on your model, you can check if replacement parts are available on the DeLonghi Spare Parts site. If your machine is still covered under the manufacturer's warranty, contact DeLonghi Customer Support to arrange for an authorized repair or a unit replacement.
Был ли этот ответ полезен?
За последние 24 часов: 3
За последние 7 дней: 23
За последние 30 дней: 112
За всё время: 827
