Dodge Durango позиционировался как надежный внедорожник на базе пикапа, рассчитанный на перевозку до семи пассажиров и буксировку до 3400 кг при соответствующей комплектации.
Need a new engine
Need new engine. Were do i get that from
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@kevinallman you can purchase remanufactured engines though the companies that specialize on this. Do an internet search and see what pops up in your region. The other thing you can do, is to speak with your "local" auto salvage yards, automotive recyclers and see if they can hook you up. Those engines usually come out of vehicles that got wrecked and are usually a bit cheaper than the rebuild/remanufactured.
I would also suggest that you consider on having your engine rebuilt. Depending on the damage and why you think you need a new engine. It may just be somewhere in the middle of the price for a recyclers engine and a remanufactured engine but at least you know what you got.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Kevin Allman буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 16
За все время: 127
