Фотокамера Sony серии HX линейки Cyber-shot.
My camera have lens problem
I want to repair my camera lens because i dropped it accidentally and now when i try to turn on its just blackscreen then shutdown by itself i ask few camera shops to give a try and repair it but they dont do it
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@badzz sounds like a dislodged lens. This happens commonly when the camera was dropped with the lens extended, knocking it off the guides. Check the space around the lens and see if the spacing is equal distance all the way around. You can always try some of the recommended fixes listed on here. If none of those work, you may have to replace the lens. Use the Sony DSC HX20V HX30V Service Manual to work on it.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
badzz буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 24
За все время: 148
