Руководства по ремонту и разборке принтера Epson. Компания была основана в 1942 году как Daiwa Kogyo, Ltd., но в 1959 году объединилась с другой компанией и создала Suwa Seikosha Co., Ltd.
Epson Expression Home XP-5200 - Error 100016
Hello, I just bought an Epson Expression Home XP-5200 from a seller on eBay, and it arrived with the mentioned fault. I notified the seller, and they refunded me and told me to keep the printer.
I have now looked up this error and found many fixes.
Here is what I have tried so far.
1) Removed power cable while printer on, waited 60 sec, held power button for 30 secs, plugged power cable back in
Outcome: Ran printer, same issue.
2) Removed the side cover, unplugged the two ribbon cables nas the reseated the, the smaller one with the blue tab facing down, and the larger one with the blue tab facing up.
3) Removed the scanner completely, opened the scanner and checked all cables. Moved the carriage over to the middle, gave everything a clean, and put it all back together.
Outcome: Ran printer; scanner carriage moved to the start position, then the error code appeared again.
Now, one of the suggested fixes for these issues is a firmware update; however, the error screen will not let me do anything. I can't reset the printer, which was another suggestion. I have no ink in the printer, which was another suggestion for the error code, but I still have no way to bypass the error screen.
So, please, if anyone knows how or if I can bypass the error screen, I may be able to reset the printer. Or is this just a brick destined for land fill (recycle)
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Since you reseated the cables already and the scanner still homes up before the error occurs, then this sounds more like hardware related. It's difficult to do a firmware update when you can't get past the error screen so a malfunctioning scanner assembly or main board would make more sense in that case.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Trebor58 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 26
За всё время: 79
