Обновление MacBook Air 11" от марта 2015 года оснащено процессорами Intel Core i5 и i7 пятого поколения, что обеспечивает небольшое увеличение производительности и времени автономной работы.
No Internal or External Display Issue
Have a 2015 A1465 here (820-00164) that chimes / boots but there is no display at all. We have tested with another known display assembly & on external displays but still nothing. From what we can see we are getting readings from the outputs, but nothing, just a black un lit screen. GPU failure I thought gets a white screen. The fan is also at high speed. What can be? (I do believe that the technician has replaced the SMC 2x already).
Это хороший вопрос?
Счет 0
3 Комментариев:
Does the system respond when you use the system in Clam Shell mode you do need external keyboard and mouse here besides the external display connection. The lid must be down as the Hall sensor needs to see the lid is closed to enable the external as the primary display.
из
@danj Will try it. And update as and when.
из
Unite is dead, green light only, no fan spin, zero..... donor unit.
из
Добавить комментарий
2 Ответов
Try connecting it to an external monitor but with the lvds cable disconnected
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
@nik_one - Disconnecting the LVDS cable won't change anything here from a diagnostic sense. If the LVDS connection was corroded up then I could see that resolving a possible short.
Putting the system into Clam Shell Mode would be easier and offer a useful data point.
из
If you can get the external display to respond then you should be Ave to identify the system issue going into CPU Safe Mode. If you can't get into Clam Shell mode that points to a CPU module issue where the I/O chip part has failed.
Счет 0
Добавьте свой ответ
livfe буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 10
За все время: 100
