Полный набор информации по ремонту функциональных домашних устройств.
How to repair electrical socket plugs
How do I repair plugs when I insert an extension lead it doesn’t work
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Different countries have different wiring standards and how power is fused. So I can't tell you where to look as there are quite a few possibilities. You may want to get a local electrician in as he is equipped to deal with most of the possibilities.
Keep in mind you can get hurt if you make a mistake!
I would look for the breaker/fuse panel and locate the breaker/fuse for the outlet to see if it's still good. If not you may have a short in the line.
Был ли этот ответ полезен?
Счет 0
@humphreygxowa what country do you live in? Let's see what the wiring standards are wherever you live. What have you already checked and what have you already tried?
Счет 0
1 Комментарий:
South Africa
из
Добавьте свой ответ
Humphrey Gxowa буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 62
