charging problem with phone
Charging problem
Это хороший вопрос?
Счет 0
2 Комментариев:
Hi @ashishmukhi
If the phone is not charging, have you tried using a different, known working, compatible charger or charger cable and checked if it started to charge?
Has the phone been dropped or gotten wet at all?
What have you tried?
из Поделиться
Try using a different charging cable and plug.
Ensure the port on the phone is clear of all and any debris to the charing cable can insert properly.
Also try using a different plug on the wall to charge.
If none of these work, it would be a problem with the phone itself and then require going to a shop to be fixed.
из Поделиться
Добавить комментарий
