Выпущенная в Северной Америке в ноябре 2006 года, Wii стала первой домашней консолью Nintendo с прямой поддержкой подключения к Интернету, обеспечивающей как онлайн-игры, так и цифровую дистрибуцию игр и медиаприложений через канал Wii Shop Channel.
Drive Lens not moving.
I have the rvl-001 wii and the laser lens doesn't move along the track when I put the disc in. The only answer I found scouring the Internet is bad motor, or something might be jammed with dust or dry grease. I would like help in planning what I should do to identify the problem and how to fix it, because I don't wanna spend money to fix it.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi!
Could be many things.
It's possible that the laser died and is even unable to see the disc, hence it won't move.
It's also possible that the worm motor is broken causing the laser not to move.
And it could be the laser's clamp/bracket.
I always check the laser clamp/bracket first, if it's fine, I replace the laser. Still not working? Then I solder a new worm motor in.
You can check this guide: Замена лазерной линзы DVD-привода Nintendo Wii
Both are easy to replace (worm motor is a little soldering experience required).
I'm afraid you need to spend some money here. Glady, a laser and a worm motor is not that expensive. I would start with a new laser first, they are known to fail.
If you don't want to refurbish the drive, then just replace the whole drive and this should do the job as well. But this will be more expensive
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Adrian Proffer буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 26
За все время: 63
