Шестое поколение смарт-часов Apple с опциональной поддержкой сотовой связи, выпущенное 18 сентября 2020 года. Модель A2376, 44 мм.
Reattaching screen after battery replacement
I just replaced the battery in my Apple Watch 44mm Series 6. The battery replacement went fine but I am struggling to reattach the screen. I purchased the Screen Adhesive along with my new battery but the adhesive I received was worthless - I didn't stick anywhere. I tried using E6000, which the repair guide recommended as an alternative but it doesn't feel as though the screen is securely attached. Does the screen snap in at all, or is it just the tape/glue that holds it in place? Any recommendations for securely reattaching the screen will be appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hello,
It is only the adhesives that hold the screen in place. If you don't adhesive the screen down a lot, then the screen will come off, and you will loose all of your water resistance.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
Thank you. I'll try again.
из
@jimstone You'll need to apply pressure after the screen is adhered on otherwise the bond would not be strong enough and it'll fall off after a few days(I learnt the hard way)
из
Thanks. It is sitting with a spring clamp on it right now!
из
Добавьте свой ответ
James Stone буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 40
За всё время: 63
