Эта модель Dell 7000-й серии 2020 года представляет собой 14-дюймовый ноутбук с процессорами Intel 10-го поколения, опциональным дисплеем 4K и более компактным прочным алюминиевым корпусом.
Keyboard typing extra adjacent letters
I have a Dell Latitude with an i7-10610U. The built-in keyboard suddenly started typing extra adjacent letters. For example, when I press Q, it types QA.
The issue affects multiple keys, while the number keys seem to work normally.
I tested with an external USB keyboard, and it works perfectly with no extra letters or typing issues.
Since the issue is with the built-in keyboard, I want to try fixing it myself before replacing the entire keyboard, since a replacement is quite expensive.
What could be causing this type of hardware failure, and what can I try to repair or clean first? Is there a way to fix the affected keyboard circuits/membrane or ribbon connection without replacing the whole keyboard? Thank you
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hello,
You could just try to clean the keycaps, as dirt, dust, and debris could have an effect when typing keys. Otherwise, it isn't that worth it to repair singular keys, in which you should probably just replace the whole keyboard.
Good luck,
T
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Shechinah Belle Valenzuela буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 16
За все время: 66
