Currently lost of power
No power I don't know what happen it directly lost power since my last used
Это хороший вопрос?
Счет 0
1 Комментарий:
@jundeewong Do you mean that the toaster itself doesn't have power, or does your whole house not have power? If your toaster does not have any power, then I suggest opening it up and changing out the PSU or power cord. If your whole house does not have power, then I would suggest that you either wait for the electricians to bring the grid back up, or change the fuses if the fuses for your home has blown.
из Поделиться
Добавить комментарий
1 ответ
If you didn't check you outlet ckt breaker, then my assumption would be, u can't fix it if I told you what the problem was.
However, assuming the breaker is tripped, then the issue might be a bad middle door switch or a worn mechanism.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Jun Dee Wong буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 31
За все время: 101
