Can this be fixed?
So long I was trying to do the Dreamcast clock battery mod and I'm sure I torn off the pads and probably broke traces due to my inexperience. Is it possible to fix this?
Это хороший вопрос?
Это хороший вопрос?
yes, it is possible if it is a dbl side board. If it is a multi-layer bd, it may not be possible. You need to scrap away some solder mask (green stuff) from a trace to get copper to solder to. Then replace the damaged trace with a small gauge wire. If the issue was your soldering skill, then you need to learn how to do it b4 attempting this as you are likely to make it worse.
Был ли этот ответ полезен?
How do I find if its a dbl board or multi-layer bd?
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 27
За все время: 96
