Информация по ремонту и разборке беспроводной игровой гарнитуры Logitech G522 Lightspeed.
Why it cannot charge properly?
Why it won't charge properly? It keeps connect and disconnecting many time.
Это хороший вопрос?
Счет 0
3 Комментариев:
If yours is covered under a 2yr warranty, Logitech should honor repairs free of charge. This presumes the charging adapter, connector and headphone connector aren't damaged. Outside of warranty; try using the Guide tab to disassemble yours if the battery is worn out.
из
I think I have a similar issue. I didn't get the warranty because I assumed out of the box it would work fine. Not only does it have charging issues, but it also has issues working properly when plugged in. I have tested the USB cable, tried different USB cables, and different computers, and I am 90% sure it is the headset itself that is the issue. I have disassembled it, but I don't see any visible issue, and continuity seems good for the USB-C port. At a loss here; if you have a suggestion besides sending it back, I am all ears
из
@qwaddles if it is new, it should have a logitech warranty. If it is used or refurb, then you will have to find service info - maybe on youtube and troubleshoot/fix it or ask Logitech for service center repair.
из
Добавить комментарий
1 ответ
the charger cant supply enough current or the headphone it drawing more current than it is suppose to.
Sub a good charger or try ur chgr on a diff headset. - it could also be the cable.
If it is the headset, it will have to come apart and determine if it is a replaceable part that will fix it.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Muhd Nur Akbar буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 37
За последние 30 дней: 141
За все время: 369
