Смартфон производства Redmi с двумя камерами. Камера с поддержкой ИИ, одна качественная вспышка и круглый блок камер.
Volume up button not working
When i want to increase my volume the button is nog working
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@ernushkafaro could be an issue with the volume & power button flex cable. Of course, it is also possible that the actual voulme button is not making proper connection with the switch. Since iFixit does not yet have a guide for this, use something like this video to at least get to the flex cable. You will need to remove teh main board to get to the volume flex. The repair flex cables are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
I have the same problem, but with the volume down button and the fingerprint button. The fingerprint button works, but the ignition button doesn't.
из
Добавьте свой ответ
Ernushka Faro буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 38
За все время: 104
