Руководства по ремонту, поддержке и диагностике MacBook Air 13" 2026 года с процессором Apple M5. Выпущен 11 марта 2026 года.
My MacBook overheat at simple tasks
My MacBook is overheating on simple tasks
Это хороший вопрос?
Счет 0
1 Комментарий:
What Applications are you running and what services do you have auto running within bootup?
What is your RAM and Storage sizes and how full is the Flash NAND storage?
из
Добавить комментарий
1 ответ
What exact temperatures are you seeing, and where are you checking them? Also, what counts as a “simple task” (for example, browsing with how many tabs), and does the fan run loudly or does the Mac slow down?
First check Activity Monitor → CPU to see whether one process is using a lot of CPU, then restart and install any pending macOS updates. If it still gets unusually hot while idle, note whether it’s plugged in and whether the vents are blocked. A new Mac can run warm during setup, syncing, or indexing, but persistent overheating during light use may need service. If you can share a screenshot of Activity Monitor’s CPU tab and the Mac’s exact model/year, that’ll help narrow it down.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Hania Khushi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 49
За всё время: 58
