Эта страница поможет вам отремонтировать Dell Vostro 2520. Она содержит руководства по ремонту аккумулятора, жесткого диска, клавиатуры и многого другого!
Turns on but only white screen
Laptop turns on but there is only white screen. If I connect another monitor then it works fine. I want to fix it so screen of laptops works fine and make the portability possible.
Это хороший вопрос?
Счет 2
11 Комментариев
@amitkg Try to open up the laptop and reconnect the plug for the built-in screen!
из
Hi Theo, thank you for ur message. i did exactly as u mentioned unfortunately it doesn't work. It still 99.99% white all over the screen except 1mm upper part (that much part is good). Is there any other way to fix it without changing the screen ?
из
@amitstark let's see this "over the screen except 1mm upper part (that much part is good)" by posting a picture with your Question of what your screen shows. Добавление изображений к существующему вопросу
из
Sorry, and I added a small video. Please check it out.
из
@amitstark so it does show more than just white. This actually looks like a bad LCD panel.
из
Показать ещё 6 комментариев
Добавить комментарий
1 ответ
Выбранное решение
@amitkg a white display indicates that the LCD backlight is turning on and thus receiving the proper voltage of 19V from its power rail. The issues that your laptop shows is commonly caused by a loose LVDS display cable,a damaged display connector, a damaged LCD panel, For now, check the connector and check the cable. This error looks more like a bad LCD. Use the Dell Vostro 2520 Owner's Manual which includes a service manual, to work on your computer.
For anything odd that you may see while working on it post some pictures of that so we can see what you see and help you further if needed. Добавление изображений к существующему вопросу
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Amit K.G. буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 81
За всё время: 81
