Nintendo DS Lite был выпущен в 2006 году как преемник Nintendo DS. Разобрать это устройство просто, что облегчает выполнение ремонта.
Main Menu Skip when games plugged in
An issue Ive had on an off for years.
When the console starts up with games plugged in, both gba and/or nds, it skips the main menu and straight up boots the game. There is also no text on the touch screen (which works perfectly fine). It prioritizes the nds slot, when booting.
It also seems to not be able to save the general settings aswell or always assume you want to do settings if there is no cartridge plugged in, sending me to the start up settings pipline.
This was an issue before but was gone for some years in between. I had the system open once and "recently", but the issue only re appeared more than a month later, after more than 5 years working properly and 5/6 years working on and off without anyone touching even the battery
If this is a known issue/answered before please link me the thread as I was unable to use the right descriptors to find it.
Otherwise, Id be very thankful for your help
Это хороший вопрос?
Счет 0
1 Комментарий
oh yeah, since the also happened just now and also happens every now and then: Sometimes it seems to keep the settings and does start booting in the main menu but only when there is not cartridge.
It is somewhat of a middle state
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
Hi!
Usually this is related in the settings.
Autoboot can be turned on or be turned off when a game is in.
There is no specific way to update the firmware.
You can remove the battery and wait 2 minutes and install it. It shouldn’t format or reset the settings but will put it in default state.
I would double check the settings and make sure which one is selected. Autoboot on or off.
Thank you!
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Jup that helped. Didn't even know this existed.
It doesnt, however, explainy why this setting changed without anyone touching the settings
из Поделиться
Your welcome!
That is weird indeed. Somehow it must have reset something.. hopefully it stay good from now on. If you are still experience issues, please let me know :)!
из Поделиться
Добавьте свой ответ
MiReS буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 27
За все время: 89
