Taillight keeps popping out
2021 F-150: Can I use clear silicone to keep the taillight in place?
Это хороший вопрос?
Это хороший вопрос?
Year, model? Using one model for example (2020 Ltd rwd), there are four mounting points (highlighted in yellow); two metal balls that are pressed into a plastic socket in the chassis and two plastic columns for screw mounting. Click on image to open a larger view of it.
Был ли этот ответ полезен?
You might have striped screw mounts and if the ball sockets might be spring loaded. appropriate lube.
За последние 24 часов: 2
За последние 7 дней: 44
За последние 30 дней: 44
За всё время: 44
2 Комментариев
The entire tail light assembly popping out of its (broken?) mounts or the outside lens? Was this a result of damage?
из F Dryer
Due to damage. The whole taillight doesn't come out just one side of it.
из Leondais Smith
