Руководства и поддержка для различных марок и типов телевизоров (ТВ).
My TV is squeaking
My TV started making a squeaking noise after we had a power outage. Before the power outage, the TV was working normally and had never made this noise. After the outage, it started squeaking while plugged in. I unplugged it completely overnight, but when I plugged it back in the next day, the squeaking started again. My boyfriend lightly tapped the outside of the TV near the power button, and the squeaking became faster and a little louder. It continued making the noise until he unplugged the TV. What could be causing this, and is it safe to use the TV?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
could be a lot of things. My first suspect would be bad capacitor(s). You will have to open it up and do a carefull inspection of all the electrolitic capacitors. I suspect one might be overheating and blowing out dielectric material. Other than that, it could be many other things.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
reina ᢉ𐭩 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 7
За всё время: 7
