Руководства по ремонту, разборке и устранению неисправностей для Apple iPad 9-го поколения с Wi-Fi, доступного с накопителем объемом 64 или 256 ГБ. Выпущен в сентябре 2021 года. Идентифицируется по номеру модели A2602.
Stuck in Restore loop, can anyone help please?
My iPad is stuck in a loop. While using it, the screen went blank and then started buffering. I turned it off and back on and a Recovery page appeared. “This iPad encountered an issue while starting etc…I pressed continue and the next page was Diagnostic Data Collection, I selected “Send Data to Apple” and was asked to Enter Passcode, which I did, and then connected to the Wi-Fi Network. The next page said “Recovery Underway”. The following page stated “No Known Issues Found” and to “Restart iPad”. I followed this instruction and restarted. The Apple logo appeared, it beeped a few times and then after a few seconds the Recovery page appeared. Back to square one! I have tried this several times with the same result.
I have also tried to Restore while connected to my iMac and also through iTunes from a tutorial found on YouTube. All have had the same result. Can anyone help please?
Это хороший вопрос?
Счет 0
2 Комментариев:
Hi Theo, I’m not really sure what DFU bug lists are but thank you for replying
из
Добавить комментарий
1 ответ
Boot the iPad into DFU mode and restore it using 3uTools
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Tracy Harrison буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 14
За последние 30 дней: 38
За всё время: 38
