front loader mildew smell
my front loader washing machine has a bad oder. I've cleaned the front filter checked the soap dispenser and the cleaned the rubber seal. I leave my door open after use and do a cleaning cycle regularly. despite my upkeep and maintenance the washing machine has suddenly developed a mildew oder. I believe I need to take it apart but need to know how.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Before taking the machine apart, I’d check the less obvious places again, especially the drain pump area and the folds behind the rubber seal. Those areas can hold moisture and residue even when the visible parts look clean. If the smell still remains, the exact model number would help determine what can safely be removed for a deeper clean.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Annalise Porto буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 40
За все время: 63
