Руководства по ремонту, разборке и поиску неисправностей контроллеров Joy-Con 2 для Nintendo Switch 2.
ZL Button Spring not working
I am trying to reassemble the left Joycon 2, and when I want to attach the ZL button, it feels like the spring is not doing its work. The ZL button is really steady and almost rubbing the button, so with a little touch it will press it.
Update (09/28/26)
Hello,
I was changing the covers. At the end I found the issue. The flex was not seating well on the support. From the top it looked like it was in the support, but I saw it sideways and it was not. This is why the ZL button was almost touching the button.
Thank you for reaching out!
Это хороший вопрос?
Счет 0
2 Комментариев
Hi!
Glad that you figured it out :)! Have a great day!
из Поделиться
Thank you! I was about to just accept I busted my controller until I found this.
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi!
Please follow this to step 13: Замена джойстика левого контроллера Joy-Con 2
Could you show us how the spring look like?
What is the reason you opened it? Is another shell used or is this a cover that you have put on?
I know that some shells do not fit completely and could cause this as well.
Thanks!
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
David Sandoval Galiana буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 24
За последние 30 дней: 83
За все время: 133
