Инструкции по ремонту и поддержка материнских плат и процессоров.
Question about CPU diagnostics
Is it possible to diagnose with 100% accuracy whether a CPU is physically damaged when it has malicious software and is only partially compromised—especially if all your other devices are in the same condition, and you don’t have clean installation media or any way to replace or reflash the motherboard BIOS?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If the system is able to boot up under its OS without errors the CPU has not failed, it's possible the system’s firmware could be infected which may create issues. Many of the better antivirus Apps can scan the firmware as well as OS-level infections.
I would start there, diagnostics won't catch all possible failures. You state other devices are encountering issues what are you seeing? Are you getting any errors?
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Needhgcspqiatrics буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 22
За все время: 41
