Makita XDT08 — это аккумуляторный ударный шуруповерт, предназначенный для профессионального использования, оснащенный бесщеточным двигателем и совместимый с литий-ионными аккумуляторами LXT 18 В. Благодаря габаритам 14,9 см x 8,3 см x 23,2 см и шестигранному патрону 1/4 дюйма, он обеспечивает высокий крутящий момент и скорость для выполнения различных задач по закручиванию крепежа.
cracking the driver case
I need to replace the switch. I have all of the screws out but the yellow plastic peice at the bottom is preventing me from cracking the case open. I have pryed on it with a screw driver and it won't separate. I don't want to break it. How do I split this open without damage.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Yeah, I wouldn’t keep hammering that yellow piece with a screwdriver. On the XDT08, the housing is held together by eight 3×16 screws, and the parts diagram shows the housing as a two-piece housing set. The switch itself is part 650689-0.
That yellow piece you’re seeing at the bottom is probably the battery terminal/support area catching on the housing. When you separate the halves, work around the housing seam with a thin plastic pry tool and gently work the halves apart rather than prying directly against the yellow plastic. The same basic Makita housing procedure on these impact drivers is to separate the two shell halves carefully while keeping the yellow battery-terminal piece seated in the lower housing. Once you get a small gap, go around the perimeter and release the shell little by little. Don't force one spot. There may also be wiring and the controller sitting in the housing, so I'd rather spend five minutes working the seam than crack a $30-ish housing or pull a wire loose.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Brian Taylor буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 33
За все время: 81
