Выпущенный 24 сентября 2021 года, iPhone 13 mini является уменьшенной версией iPhone 13 от Apple и вторым iPhone в линейке mini. Он оснащен 5,4-дюймовым OLED-экраном, процессором A15 Bionic и двойной основной камерой.
Changing Display and Proximity Sensor
Hi, I have rather a specific issue with this iPhone. It has been given to me as a second use phone and I decided to repair it. From my knowledge the display is a third party item (LCD I think), the touch is likely dead (unresponsive) I do not think something is wrong with the flex cable itself as it seems undamaged to me. And also the connector at the end of the flex cable for Proximity Sensor has 2 pins chipped off.
My question is. Is it worth it to try and bring to a working state? Would buying a new Proximity Sensor fix the unresponsive display? The FaceID?
Thanks for any reply.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
A new proximity sensor won’t fix an unresponsive touchscreen. The touch issue is more likely the third-party display, its flex cable, or the connector on the logic board. I’d test with a known-good compatible display first.
The damaged proximity sensor flex may affect proximity functions, and if the damage involves the original TrueDepth/Face ID components, Face ID may also be affected. Don’t replace those parts blindly; identify exactly which connector is damaged and test each issue separately before spending more money.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Pracovny буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 63
За все время: 63
