Руководства по ремонту и информация по диагностике микроволновых печей.
Micro wave not heating up
Can you repair a micro wave
Это хороший вопрос?
Счет 0
1 Комментарий
@roberthousden No, because the "I" in iFixit means YOU! We teach you how to fix your stuff.
Now, what is the Microwave that we are working with? Make and model? We need some information here before we throw out a answer to you.
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
The short answer here is that yes, a microwave oven can be repaired in most cases.
As Theo already stated, we can't do anything without knowing which microwave you have, as repair and troubleshooting procedures will vary widely among different models and manufacturers.
Failing to heat can be caused by any number of problems, so diagnostic steps would need to be taken to determine what failed. Are you comfortable using a multimeter? Can you safely discharge the high voltage capacitor inside the oven? Are you knowledgeable about safety procedures for high voltage circuits?
If you answered no to any of these questions, you'll be better off taking it to a repair shop than trying to work on it yourself. There are potentially lethal voltages present inside so precautions must be taken in order to safely work on it.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Robert Housden буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 35
За все время: 35
