Window not working properly
Window not going up and down properly
Это хороший вопрос?
Счет 0
1 Комментарий:
Can you clarify your question? Does the window have trouble moving, or are you having problems with the switch? Exactly what happens when you try to raise or lower the window? The better you can explain the problem, the more chance we have of being able to help you figure it out.
Also, what year is your Beemer? Is there any specific model information we should know? Is it just one window, or are you having issues with more than one? Which window is having the problem?
из Поделиться
Добавить комментарий
