I can't change the program
Can't change the program. No error code
Это хороший вопрос?
No error code is information: the board is not reporting a failed sensor. That puts the fault in the command path, the panel that picks the program and the wire that carries the choice to the board, not in the wash side.
jayeff's power cycle is the right first move. If it reset it once and it locked again, that timing is the clue, so write down what happened.
1. Time it. After the unplug, does it change programs for one selection, one full cycle, or not at all? Works cold, fails warm points at the panel or the board, not at a worn switch.
2. Exact model. Read the plate, usually on the door edge or the side of the door, and give me the full string. Asko changed panel designs a lot between generations and I will not guess a button combination without it.
3. Panel lock. Most Asko panels have a key lock: you hold a combination for a few seconds, and the panel then ignores everything. Look for a lock symbol or a padlock on the display. Do not try random combinations, look the combination up for your model in the manual. This one gets people for a week before they find it.
4. Door latch. Shut the door firmly, press the latch area in with your thumb, then try to change the program. If it responds only while you are pressing the door, the latch switch is worn or the hinge has dropped and the board thinks the door is open.
5. Knob selector? Unplug, pull the knob straight off, turn the shaft by hand through every position, feel the detents. Then power up in a quiet room and listen at the console as you turn. One click per position means the switch is reporting. Silence means it is not.
6. Touch panel? Look at the panel seam and the top edge for water creep, and check the ribbon where it folds at the door hinge. A cracked ribbon at the fold gives exactly this: display alive, no error, most keys dead.
7. Connectors. Pull the panel ribbon off the main board at the back, look at the pins for green creep or a pushed-back pin, reseat it once and test. Then stop reseating.
8. Heat. Powered five minutes, feel the board over the relays. A spot too hot to hold a finger on is where the fault lives.
Back to me with: exact model, knob or buttons, whether a lock symbol shows, what the power cycle did and how long it lasted, and whether you hear a click at the console when you turn or press the selector.
Был ли этот ответ полезен?
За последние 24 часов: 4
За последние 7 дней: 26
За последние 30 дней: 26
За все время: 26
Hi @marnie41623
What is the model number of the dishwasher?
Try disconnecting the power from the dishwasher for about 5 minutes and then reconnect it and check if this has reset the dishwasher allowing you to change programs.
из jayeff Поделиться
