Руководства по ремонту, разборке и диагностике 14-дюймового MacBook Pro с чипом M5, выпущенного в октябре 2025 года. Идентификатор модели — A3434.
Irremovable Marks on Screen
Hello, I've been using a 14" Macbook Pro for a little over six months now, and I've noticed some marks on my display that, no matter how much I try to clean off, look to be permanent. I've used "Whoosh!" screen cleaner and 70% isopropyl alcohol, but there's always some marks left, sometimes even visible at high brightness. I think it's worth mentioning I sometimes use my laptop closed for long periods of time, potentially exposing the display to higher than average temperatures. Although I've heard that this is safe, I feel that this could have contributed to this. Has anyone else experienced this? How can I get rid of them and prevent them from re-appearing or getting worse? Thank you.
Это хороший вопрос?
Счет 0
3 Комментариев
hmm could be the antireflective coating wearing off because of the heat somehow although its unlikely. It could ofc also be the keyboard leaving imprints on the screen but we'll need pictures to confirm : Добавление изображений к существующему вопросу
из Поделиться
A photo taken at an angle with the screen off and a bright light reflecting across it would help a lot here. If the marks line up with the key rows, it is usually contact imprinting rather than heat, and a thin microfiber sheet between keyboard and screen when closed can stop it getting worse. Since it is only six months old, it may also be worth asking Apple to look at the coating before trying anything more abrasive.
из Поделиться
@leooooo1061 I've attached a couple images to the post. The keyboard imprint as well as some marks outlining the trackpad are definitely visible under a light.
из Поделиться
Добавить комментарий
1 ответ
Наиболее полезный ответ
@shawnlee95891 - I do find the newer models (2016 onward) tend to get rub marks from the keys, mostly when using a backpack that has stuff pressing on the lid directly.
I use a clean thin micro-cloth which fits over the keys preventing the keys from hitting to prevent that.
As far as damage running in clamshell mode the 2016 ~ 2019 systems tend to run hot with the Intel CPU's which did damage the T-CON logic from heat buildup. Since the M1 and newer M Series chips the heat issue has not been a problem and Apple did redesign the system to prevent the T-CON heat issue. So I wouldn't worry about that.
Update (11/25/26)
@shawnlee95891 - Sadly, you are facing key rubbing onto the screen
For now just use a micro-cloth dampened with kitchen spray cleaner to wipe down the keys and trackpad, don't spray the system! And use a good screen cleaner on the display to reduce the risk as well as making sure you aren't resting anything on the lid.
You might find a glass screen protector can improve things a bit as optical adhesive can fill-in some of the imperfections. I did that on my system as I wanted a matte finish to cut the glare. You do give up a little bit of the sharpness. The other choice is narrow-view which is a special polarizer to remove people looking over your shoulder to see the image on the display.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Shawn Lee буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 25
За последние 7 дней: 44
За последние 30 дней: 44
За все время: 44
