Выпущенный в июне 2009 года, 1005HA отличается своим дизайном «Seashell» и доступен во многих различных вариациях в зависимости от операционной системы, внутреннего накопителя и емкости аккумулятора.
How to replace the internal clock battery
How to replace the internal clock battery ?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
harveyf, here is a decent video on how to change the battery. Also, do not forget to look through the guides on here to learn a bit more about this model. Hope this helps, good luck.
Был ли этот ответ полезен?
Счет 0
BTW, you might want to know before you open the case that the battery you are replacing is labeled "ML1220/2E2E0X", which is a small watch-style cmos button battery soldered to a wire pigtail, so it's ready to plug in.
They can be found on ebay or Amazon; if you're paying more than $5 including shipping, you're being ripped off.
Another option is un-solder the original, find a generic ML1220 battery, and then solder the old pigtail connector to it, using shrink-wrap tubing to seal things back up.
[This battery is probably identical to the very common CR1220, both being 3V lithium button batteries. Dunno. Switch to a different model if you don't mind the uncertainty and risk.]
Счет 0
Добавьте свой ответ
harveyf буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 48
За все время: 10,700
