Backspeaker shortcut rear speakers?
Hi.
I have now destroyed my cdplayer thanks to a shortcut in my rear speakers.
How do i change the rear speakers wthout destroying anything at the back of my car?
Can someone give me a step-by-step writedown on how to do it?
Это хороший вопрос?
3 Комментариев
What happened to your CD player that makes you believe that it is destroyed from a bad speaker? What have you tried so far to find the error? I think I would check the wiring harness first. If you give us more of a description of what is going on with your CD player and speakers, we could try to assist you further.
из oldturkey03 Поделиться
There is a certain sound in the speakers when it is a short circuit. I have tried a lot of things, but it was when i tried to connect an Amplifier to the back speakers i really knew. As you know you got to have separate cables from the Amplifier to the speakers. When i started the system the Amplifier instantly switched to " safe mode". ( sorry for my bad spelling/grammar, hope you understand what i mean )
из Robert Поделиться
Have you checked you original wiring harness , just to make sure there is no short circuit in the wiring? I would use a separate speaker to make sure that everything else is working okay. Temporarily replace one rear speaker and see what it does.
