Введение
Use this guide to open your Apple Watch Series 8 for repairs.
Note: The opening procedure for the 41 mm and the 45 mm Apple Watch series 8 is the same. You can use this guide for both models.
This guide shows the procedure on the cellular/LTE version of the watch, but the GPS-only version is similar.
You’ll need replacement adhesive for the screen when reassembling the device.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:iFlex Opening Tool$11.99
Prepare an iOpener and apply it to the screen for three minutes to loosen the adhesive underneath.
Insert the iFlex into the thin gap between the display and frame at the edge adjacent to the digital crown.
Tilt the iFlex down to pry the display open slightly and create a gap between the screen and the watch body.
Insert the tip of an opening pick into the gap you just created.
Slide the opening pick along the short edge of the watch to slice the adhesive.
Slide the opening pick around the corner and along the long edge opposite to the watch crown to slice the adhesive.
Slide the opening pick around the corner and along the next short edge to slice the adhesive.
Slide the opening pick around the corner and toward the watch crown to slice the remaining adhesive.
Lift the display and carefully pull it towards the watch crown.
Swing the display open to an upright position.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Еще один человек закончил это руководство.
