Apple Watch Series 7 Battery Replacement
Выберете то, что вам нужно
  1. Apple Watch Series 7 Battery Replacement, Power down the watch: шаг 1, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Power down the watch: шаг 1, изображение 2 из 2
  2. Apple Watch Series 7 Battery Replacement, Safety Requirements: шаг 2, изображение 1 из 3 Apple Watch Series 7 Battery Replacement, Safety Requirements: шаг 2, изображение 2 из 3 Apple Watch Series 7 Battery Replacement, Safety Requirements: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Safety Glasses
    $3.19
    Купить
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Attach or remove the watch band as needed to provide more control as you make repairs.
  3. Apple Watch Series 7 Battery Replacement, Soften the display adhesive: шаг 3, изображение 1 из 1
    • Prepare an iOpener and apply it to the screen for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the watch—the display and internal battery are both susceptible to heat damage.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive softens.
  4. Apple Watch Series 7 Battery Replacement, Create a gap: шаг 4, изображение 1 из 3 Apple Watch Series 7 Battery Replacement, Create a gap: шаг 4, изображение 2 из 3 Apple Watch Series 7 Battery Replacement, Create a gap: шаг 4, изображение 3 из 3
    • Be aware that a sharp tool easily scratches your watch housing when not handled with care. To avoid undesired scratches, take your time and work carefully rather than hastily.
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
    • Once inserted, tilt the blade to pry the display open slightly and create a gap between the screen and the watch body.
    • The Apple Watch Series 7 display is equipped with a plastic bezel on its rear side. If you want to reuse your display, avoid using too much pressure with the knife or you may separate the bezel from the screen.
  5. Apple Watch Series 7 Battery Replacement, Slice the adhesive: шаг 5, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Slice the adhesive: шаг 5, изображение 2 из 2
    • Insert an opening pick in the gap your created.
    • Slide the opening pick along the short edge of the watch to slice the adhesive.
  6. Apple Watch Series 7 Battery Replacement: шаг 6, изображение 1 из 2 Apple Watch Series 7 Battery Replacement: шаг 6, изображение 2 из 2
    • Slide the opening pick around the corner and along the long edge on the opposite side of the watch crown to slice the display adhesive.
  7. Apple Watch Series 7 Battery Replacement: шаг 7, изображение 1 из 2 Apple Watch Series 7 Battery Replacement: шаг 7, изображение 2 из 2
    • Slide the opening pick around the corner to slice the remaining adhesive on the short edge of the watch next to the watch crown.
    • Don't try to remove the display. It is still connected to the watch assembly.
  8. Apple Watch Series 7 Battery Replacement, Swing open the display: шаг 8, изображение 1 из 3 Apple Watch Series 7 Battery Replacement, Swing open the display: шаг 8, изображение 2 из 3 Apple Watch Series 7 Battery Replacement, Swing open the display: шаг 8, изображение 3 из 3
    • Be careful not to strain the display cables when you fold the display to the side.
    • Lift the display and carefully pull it towards the watch crown.
    • Swing the display open to an upward position.
  9. Apple Watch Series 7 Battery Replacement, Soften the battery adhesive: шаг 9, изображение 1 из 1
    • Prepare an iOpener and apply it to the rear side of your Apple Watch for at least two minutes to loosen the adhesive underneath the battery.
  10. Apple Watch Series 7 Battery Replacement, Determine which procedure to follow: шаг 10, изображение 1 из 1
    • From this point, the battery removal procedure for the 41 mm watch differs slightly from the 45 mm version.
    • If you're replacing the battery for a 41 mm watch, continue with this step.
    • If you're replacing the battery for a 45 mm watch, continue with this step.
  11. Apple Watch Series 7 Battery Replacement, Pry up the battery: шаг 11, изображение 1 из 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: шаг 11, изображение 2 из 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: шаг 11, изображение 3 из 3
    • The following six steps show how to remove the battery from a 41 mm Apple Watch Series 7.
    • Insert an opening pick between watch body and the long edge of the battery.
    • Use constant, steady pressure to slowly pry up the battery.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Don't try to remove the battery all the way yet. It is still connected to the motherboard.
  12. Apple Watch Series 7 Battery Replacement, Move the battery: шаг 12, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Move the battery: шаг 12, изображение 2 из 2
    • The battery flex cable is long enough to allow you to place the battery outside the watch housing, but avoid straining or folding the the cable sharply when you lift the battery out of its recess.
    • Carefully lift and swing the battery out of its recess and place it next to the watch body.
  13. Apple Watch Series 7 Battery Replacement, Peel the black protective tape off the ZIF connector: шаг 13, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Peel the black protective tape off the ZIF connector: шаг 13, изображение 2 из 2
    Купить
    • Use a pair of tweezers to peel the black protective tape off the ZIF connector.
    • Make sure to only peel the tape off the connector but avoid to remove it completely. Otherwise you have to replace the tape during reassembly.
  14. Apple Watch Series 7 Battery Replacement, Open the ZIF connector: шаг 14, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Open the ZIF connector: шаг 14, изображение 2 из 2
    • Use one arm of your tweezers or the pointed end of a spudger to pry up the lock bar on the ZIF connector securing the battery cable.
  15. Apple Watch Series 7 Battery Replacement, Disconnect the battery: шаг 15, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Disconnect the battery: шаг 15, изображение 2 из 2
    • Use a pair of tweezers to pull the battery cable out of the battery ZIF connector.
    • During reassembly make sure to push the cable all the way back into the ZIF connector before locking the it. Reapply the black tape on top of the connector to secure the battery cable or replace it with new one. Otherwise the battery cable may slip out of the connector and your watch won't turn on.
  16. Apple Watch Series 7 Battery Replacement, Remove the battery: шаг 16, изображение 1 из 1
    • Remove the battery.
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • If you're reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly.
    • Secure a new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
  17. Apple Watch Series 7 Battery Replacement, Pry up the battery: шаг 17, изображение 1 из 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: шаг 17, изображение 2 из 3 Apple Watch Series 7 Battery Replacement, Pry up the battery: шаг 17, изображение 3 из 3
    • The following six steps show how to remove the battery from a 45 mm Apple Watch Series 7.
  18. Apple Watch Series 7 Battery Replacement, Move the battery: шаг 18, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Move the battery: шаг 18, изображение 2 из 2
  19. Apple Watch Series 7 Battery Replacement, Unfasten the battery connector bracket screw: шаг 19, изображение 1 из 1
    • Use a Tri-Point Y000 screwdriver to remove the 1.1 mm-long screw securing the battery connector bracket.
  20. Apple Watch Series 7 Battery Replacement, Remove the battery connector bracket: шаг 20, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Remove the battery connector bracket: шаг 20, изображение 2 из 2
    • Use a pair of tweezers to remove the battery connector bracket.
  21. Apple Watch Series 7 Battery Replacement, Disconnect the battery cable: шаг 21, изображение 1 из 2 Apple Watch Series 7 Battery Replacement, Disconnect the battery cable: шаг 21, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  22. Apple Watch Series 7 Battery Replacement, Remove the battery: шаг 22, изображение 1 из 1
    • If you're reusing your old battery, you can reuse the existing adhesive to secure the battery during reassembly.
    • During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
For optimal performance, calibrate your newly installed battery after completing this guide.
8 участников успешно повторили данное руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
204 319 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 288 руководств
4 Комментариев
Is it still waterproof after that? I swim daily. Watch is 2.5 years old doing great but the battery is at 76%.
Will the adhesive on the screen seal back up good enough?
Matt Reason - Ответить
Hi Matt,
retaining water resistance after the repair depends on how clean the mating surfaces are and how accurately the adhesive is reapplied. Your device will lose its factory-given IP (Ingress Protection) rating. Personally I wouldn‘t advise to go swimming with the watch after resealing it with tape.
Dominik Schnabelrauch -
if the socket that the battery plugs into breaks, is that something worth paying to fix, or should i just buy a new watch?
river D - Ответить
Bravissimo,tutto molto chiaro.
Aldo Sammartano - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 99
За последние 7 дней: 815
За последние 30 дней: 3,638
За всё время: 36,765
