Archos 5 Battery Replacement
Выберете то, что вам нужно
  1. Archos 5 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Please be sure that your device is powered off before attempting any repairs.
    • Please be aware that any further steps could possibly void the warranty of your Archos 5.
    Спросите у FixBot
    Добавить комментарий
  2. Archos 5 Battery Replacement: шаг 2, изображение 1 из 2 Archos 5 Battery Replacement: шаг 2, изображение 2 из 2
    • Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
    • Use the screwdriver(PH000) to remove the screws located under the pads.
    • Lift the stand in order to get to the fourth screw.
    Спросите у FixBot
  3. Archos 5 Battery Replacement: шаг 3, изображение 1 из 2 Archos 5 Battery Replacement: шаг 3, изображение 2 из 2
    • Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
    • Once all sides of the device are pried open, gently open the device .
    • Be careful not to tear the foil which connects the LCD screen to the motherboard!
    Спросите у FixBot
  4. Archos 5 Battery Replacement: шаг 4, изображение 1 из 2 Archos 5 Battery Replacement: шаг 4, изображение 2 из 2
    • Once you have opened your device, fold the screen away from the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece(attached at the bottom of the metallic foil) Press the plastic spudger against the thin black piece and release it.
    Спросите у FixBot
  5. Archos 5 Battery Replacement: шаг 5, изображение 1 из 1
    • Separate the grey tape by using a plastic spudger. The tape is holding the battery in place.
    Спросите у FixBot
  6. Archos 5 Battery Replacement: шаг 6, изображение 1 из 3 Archos 5 Battery Replacement: шаг 6, изображение 2 из 3 Archos 5 Battery Replacement: шаг 6, изображение 3 из 3
    • Now begin to remove the battery by prying it away with the plastic spudger. Please note that the battery is glued to the device.
    • Be careful when prying the battery away from the device. Wiggle the plastic spudger under the battery if necessary to loosen the glue.
    Спросите у FixBot
  7. Archos 5 Battery Replacement: шаг 7, изображение 1 из 1
    • Locate 3 wires(red, blue and black) that connect the motherboard and the battery.
    Спросите у FixBot
  8. Archos 5 Battery Replacement: шаг 8, изображение 1 из 3 Archos 5 Battery Replacement: шаг 8, изображение 2 из 3 Archos 5 Battery Replacement: шаг 8, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • After locating the wires (red, blue, and black) firmly pull the wires using tweezers and release them from the motherboard.
    • Continue to does this to the remaining two wires.
    Спросите у FixBot
  9. Archos 5 Battery Replacement: шаг 9, изображение 1 из 1
    • Once the wires have all been released remove the battery from the device and replace with a new battery. To reattach the new battery wires please refer to this guide on How To Solder
    Спросите у FixBot
Заключение
7 человек успешно провели ремонт по этому руководству.
Ally Hummel
Участник с: 09/22/15
381 Репутация
Автор 3 руководств
Команда
University of Alabama, Team 1-5, Sydow campbell Fall 2015 Участник University of Alabama, Team 1-5, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G5
4 членов
Автор 6 руководств
2 Комментарии к руководству
Where I can find this battery?
mitkekg - Ответить Поделиться
CA564889 - Battery
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 12
За последние 30 дней: 75
За всё время: 12,761
