Azpen A740 Camera Replacement
Выберете то, что вам нужно
    1. Azpen A740 Camera Replacement, Back Panel: шаг 1, изображение 1 из 1
      • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
      Спросите у FixBot
      Добавить комментарий
    1. Azpen A740 Camera Replacement, Camera: шаг 2, изображение 1 из 1
      • You should see the motherboard, the speaker, and the battery.
      • The camera is surrounded by the red square.
      Спросите у FixBot
    2. Azpen A740 Camera Replacement: шаг 3, изображение 1 из 1
      • The camera is located at the top of the device and is attached by one screw with 3.75mm which is inside of the red circle. And one clip which is inside of the orange rectangle.
      • First remove the screw from the plastic connecting the camera to the motherboard.
      • The ZIF connector attaching the camera to the motherboard.
      Спросите у FixBot
    3. Azpen A740 Camera Replacement: шаг 4, изображение 1 из 1
      • With the plastic now removed from the camera, the user is able to unclip the camera from the motherboard by pulling up the black clip and sliding out the camera.
      • Here you can see the rear camera is on the top and the front camera is on the top. As you can see, it is not possible to replace one camera and not the other.
      Спросите у FixBot
    4. Azpen A740 Camera Replacement: шаг 5, изображение 1 из 1
      • This is what the camera looks like once completely removed from the tablet.
      • This is where the camera was previously, it is the place where the new camera must be placed.
      Спросите у FixBot
    5. Azpen A740 Camera Replacement: шаг 6, изображение 1 из 1
      • Now you are able to insert the new camera.
      • To reassemble your device, follow these instructions in reverse order.
      Спросите у FixBot
Заключение
Victoria Poitier
Участник с: 01/21/15
101 Репутация
1 руководство автора
Команда
USF Tampa, Team 4-5, Brown Winter 2015 Участник USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 членов
Автор 18 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 26
За всё время: 453
