Введение
Use this guide to replace the mainboard on the left controller handle in your Backbone one.
Выберете то, что вам нужно
Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
Lift up the upper part of the controller.
Swing over the upper cover and place it on the controller case.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
Use your fingers to disconnect the interconnect cable from its connector.
Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
Use a Phillips screwdriver to remove the four 3.9 mm-long screws.
Repair didn’t go as planned? Ask our Answers community for help.
2 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
In my unit, there were two more screws at step (10), in the upper part of the controller, near the trigger. They may have changed the number of screws used in manufacturing at some point.
