Введение
Use this guide to replace the LCD Display if it is cracked or not functioning properly on your Canon PowerShot A200.
A functioning LCD Display uses its liquid substances to properly create images on the screen of your camera.
A broken LCD screen could be hazardous to the skin. If broken, take appropriate precautions.
Once the case has been disassembled, a new LCD Display can be installed.
Make sure there is some experience with working with difficulty as soldering will be needed to reassemble the camera together.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to remove the two screws located at the bottom of the camera.
Locate the screw and the rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
Remove the two screws with the Phillips #00 screwdriver.
Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
Remove the two visible screws with the Phillips #00 screwdriver.
Remove the screen battery located to the left of the screen.
Set the screen battery aside for reassembly
Инструмент, используемый на этом этапе:Tweezers$4.99
Locate the black tabs on either side of the white ribbon.
Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
Gently pull the white ribbon out from its connection.
Locate the black tabs on either side of the orange ribbon.
Gently pull the orange ribbon out of its connection.
Use a Phillips head screwdriver to remove the four screws from the corners of the LCD.
Use a soldering iron to remove the LCD from the orange cable connected to the back of the camera.
Use the soldering iron to attach your new LCD in place.
Follow the instructions in the prerequisite guide Disassembling the Canon PowerShot A200 Case.
Once completed, proceed with installing a new LCD Display.
