Введение
A zipper slider is responsible for joining the two sides of the zipper and ensuring the teeth secure properly. When a slider is damaged or missing, the zipper will not stay closed and the slider needs to be replaced.
This guide will demonstrate how to replace the slider on a coil zipper.
IMPORTANT! Before proceeding:
- Ensure that the zipper separates at the top and bottom (e.g. a center front jacket zipper) and the top and bottom are not sewn together (e.g. a pocket zipper)
- Identify the type of zipper to obtain the correct replacement part
- Ensure that the issue can be fixed with a slider replacement and doesn't require a full zipper line replacement
Read through the entire guide before starting the repair, and gather the necessary tools and materials. While Patagonia-specific materials are ideal, they are not required. Patagonia replacement parts can be obtained by calling or messaging Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for a repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 3 or under. Instead, we recommend return of the product for professional repair services.
The 3 Stages of Patagonia Zipper Repair
- Identify the zipper type
- Diagnose the issue
- Repair the zipper
- Coil Zipper Slider Replacement
- Plastic Tooth Zipper Slider Replacement
- Advanced No-Sew Zipper Repair Techniques
Выберете то, что вам нужно
Gather tools and the two pieces required for a coil slider replacement:
A replacement slider that is the right size and style
A coil top stop in the correct size
Unzip the zipper.
Locate the top stop at the top of the zipper on the side with the slider.
Peel back any fabric that is covering the top stop.
Slide the damaged zipper slider up and off the zipper tape.
Discard the zipper slider responsibly.
Making sure the new slider is oriented correctly, slide it onto the zipper tape.
Once the slider is on the zipper, test zipping up the jacket to make sure it's the right slider type and that the issue is fixed.
Place the top stop on the flat, tape side of the zipper, aligning the double-prong side of the stop to face the jacket and the single-prong side to face the zipper teeth.
Slide the single-prong beneath the first or second tooth at the top of the zipper tape.
Push the double-prongs through the zipper tape so they emerge on the opposite side, on the inside of the coil.
Use pliers to bend the prongs of the stop inward, clamping them around the zipper coil. The prongs will grab into the coil, securing it in place.
Check that the new stop effectively prevents the new slider from coming off the zipper.
22 человек успешно провели ремонт по этому руководству.
11 Комментарии к руководству
Where do I get the zipper stop????
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
Great now how ! thank’s :)
