Введение
This is a replacement guide for the DJI Mini 2's propeller blades.
The propellers are on the DJI Mini 2 help the drone generate lift for the drone when it is flying. A drone propeller will need to be replaced if the propeller is damaged and causes the drone to hover in an inconsistent way.
Выберете то, что вам нужно
Open up the propeller arms to make it easier to access the propeller blades.
Then, place the drone on a flat surface.
Remove the 7mm J000 head screw attaching the blade to the motor.
Remove the propeller blades.
