Dell Precision 3541 Battery Replacement
Выберете то, что вам нужно
  1. Dell Precision 3541 Battery Replacement, Battery: шаг 1, изображение 1 из 3 Dell Precision 3541 Battery Replacement, Battery: шаг 1, изображение 2 из 3 Dell Precision 3541 Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • The first step for battery replacement is to remove the base cover which is the bottom panel of the device. You will find a total of eight small screws, three on each side, and two in the middle of the panel. Once all screws are removed, it may be helpful to use a flat, pointy tool such as a paint key, to pop the panel off of the device.
    Спросите у FixBot
    Добавить комментарий
  2. Dell Precision 3541 Battery Replacement: шаг 2, изображение 1 из 2 Dell Precision 3541 Battery Replacement: шаг 2, изображение 2 из 2
    • Once looking at the interior of the underbody, you should find a rectangular encasement panel in the bottom right corner of the device. This component is the battery. On the battery, you will find one screw on the right side and two on the top. Unscrew all three carefully, putting them in a safe holding place.
    Спросите у FixBot
  3. Dell Precision 3541 Battery Replacement: шаг 3, изображение 1 из 3 Dell Precision 3541 Battery Replacement: шаг 3, изображение 2 из 3 Dell Precision 3541 Battery Replacement: шаг 3, изображение 3 из 3
    • Locate a small black cable that runs along a crevice in the underside of the battery that connects the bottom of the battery to the device. Carefully unplug the side that connects into the battery and remove the cable from its crevice. Then the battery can be removed.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Abby Lunday
Участник с: 02/26/26
231 Репутация
Автор 2 руководств
Команда
Austin Community College, Team 49-4, Cox Spring 2026 Участник Austin Community College, Team 49-4, Cox Spring 2026
AUSTINCC-COX-S26S49G4
3 членов
Автор 5 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 34
За всё время: 65
