Введение
To replace the battery you will need a sharp edged tool, be sure to be careful. The glue on the battery is sticky and hard to get off.
Выберете то, что вам нужно
With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
Using a metal spudger tool, wedge between battery and metal screen.
Follow the edge of the battery to loosen the glue.
Once the glue is loosened, you should be able to pry off the battery from the screen.
Using your hands, pull up on the battery to pull battery off.
The battery will be completely disconnected and you can set the battery aside in a safe place.
Еще один человек закончил это руководство.
3 Комментарии к руководству
the replacemet has 3 wires .where go the 3 wire?
were can i buy a new bettery
