Disassembling IBM WorkPad c3 Front Case
Выберете то, что вам нужно
  1. Disassembling IBM WorkPad c3 Front Case, Back Case: шаг 1, изображение 1 из 2 Disassembling IBM WorkPad c3 Front Case, Back Case: шаг 1, изображение 2 из 2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
    Спросите у FixBot
    Добавить комментарий
  2. Disassembling IBM WorkPad c3 Front Case: шаг 2, изображение 1 из 1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
    Спросите у FixBot
  3. Disassembling IBM WorkPad c3 Front Case: шаг 3, изображение 1 из 2 Disassembling IBM WorkPad c3 Front Case: шаг 3, изображение 2 из 2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
    Спросите у FixBot
  4. Disassembling IBM WorkPad c3 Front Case, Front Case: шаг 4, изображение 1 из 2 Disassembling IBM WorkPad c3 Front Case, Front Case: шаг 4, изображение 2 из 2
    • Turn the device over, so that the screen is laying on a flat surface.
    Спросите у FixBot
  5. Disassembling IBM WorkPad c3 Front Case: шаг 5, изображение 1 из 3 Disassembling IBM WorkPad c3 Front Case: шаг 5, изображение 2 из 3 Disassembling IBM WorkPad c3 Front Case: шаг 5, изображение 3 из 3
    • If the back case has already been removed, carefully place it on the WorkPad to protect the circuitry inside from the heat.
    • Using the hair dryer, slowly heat the edges of the device. Spend at least 1 minute on each side, thoroughly heating the case.
    • The LCD/Digitizer combo is very sensitive to heat, and can easily be ruined if it is directly exposed to the hair dryer. Verify that the screen is face down.
    Спросите у FixBot
  6. Disassembling IBM WorkPad c3 Front Case: шаг 6, изображение 1 из 2 Disassembling IBM WorkPad c3 Front Case: шаг 6, изображение 2 из 2
    • The device will be extremely hot. Use a towel or oven mitt to grab it.
    • Using the Plastic Opening Tools, take the front of the case off.
    • If the case is difficult to remove, try repeating step 2.
    • The power button at the top of the device will be loose once the front part of the case is removed.
    Спросите у FixBot
Заключение
Emily Falkenstein
Участник с: 10/05/10
75 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 21-35, Regan Fall 2010 Участник Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 членов
Автор 5 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 32
За всё время: 2,948
