Введение
This requires soldering, so for a quick lesson or just a refresher, check out How to Solder and Desolder Connections.
Выберете то, что вам нужно
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
Еще один человек закончил это руководство.
