Ematic EGQ307 Battery Replacement
Выберете то, что вам нужно
  1. Ematic EGQ307 Battery Replacement, Battery: шаг 1, изображение 1 из 2 Ematic EGQ307 Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
    Спросите у FixBot
    Добавить комментарий
  2. Ematic EGQ307 Battery Replacement: шаг 2, изображение 1 из 2 Ematic EGQ307 Battery Replacement: шаг 2, изображение 2 из 2
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
    Спросите у FixBot
  3. Ematic EGQ307 Battery Replacement: шаг 3, изображение 1 из 1
    • 3. Once you pry off the plastic backing, you will expose the battery.
    Спросите у FixBot
  4. Ematic EGQ307 Battery Replacement: шаг 4, изображение 1 из 3 Ematic EGQ307 Battery Replacement: шаг 4, изображение 2 из 3 Ematic EGQ307 Battery Replacement: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    • 4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
    • Do not bend or warp the battery. Even though the battery may not be working, it is still dangerous.
    Спросите у FixBot
  5. Ematic EGQ307 Battery Replacement: шаг 5, изображение 1 из 1
    • If replacing the battery, unplug the black and red wires gently from the hardware and take off the battery .
    • If not replacing it, do not disconnect the red and black wires.
    • If replacing the battery, you will need a soldering kit to reconnect the wires with the new battery after disconnecting the old battery.
    • How To Solder and Desolder Connections.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
2 человек успешно провели ремонт по этому руководству.
Othman
Участник с: 07/21/15
267 Репутация
1 руководство автора
Команда
Eastern Washington University, Team 1-1, Rowley SU 2015 Участник Eastern Washington University, Team 1-1, Rowley SU 2015
EWU-ROWLEY-SU15S1G1
4 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 45
За всё время: 5,549
