Framework Laptop 12 Pre-built Quick Start Guide
    1. Framework Laptop 12 Pre-built Quick Start Guide, Unbox your Framework Laptop: шаг 1, изображение 1 из 2 Framework Laptop 12 Pre-built Quick Start Guide, Unbox your Framework Laptop: шаг 1, изображение 2 из 2
      • Unbox your Framework Laptop and make sure you've received all the items:
      • Framework Laptop 12
      • Framework Screwdriver
      • Expansion Cards you selected during purchase
      • Framework Power Adapter, USB-C Cable, and AC Cable
      Спросите у FixBot
      Добавить комментарий
    2. Framework Laptop 12 Pre-built Quick Start Guide, Set your laptop on a clean surface: шаг 2, изображение 1 из 1
      • Set your Framework Laptop face-down on a clean work surface.
      Спросите у FixBot
    3. Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: шаг 3, изображение 1 из 3 Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: шаг 3, изображение 2 из 3 Framework Laptop 12 Pre-built Quick Start Guide, Install the Expansion Cards: шаг 3, изображение 3 из 3
      • Slide an Expansion Card into the Expansion Card slot.
      • All official Expansion Cards work fully in all slots, so you can install them however you wish!
      • You don't need to unlock the latches to install the Expansion Cards—only when you want to remove them.
      • The Expansion Cards should click in place, and the front edge should be flush with the laptop.
      • Repeat the procedure with the remaining expansion cards.
      Спросите у FixBot
    4. Framework Laptop 12 Pre-built Quick Start Guide, Lock the Expansion Card slots: шаг 4, изображение 1 из 2 Framework Laptop 12 Pre-built Quick Start Guide, Lock the Expansion Card slots: шаг 4, изображение 2 из 2
      • If there's a red bar showing under each Expansion Card latch, use your finger to flip the latch and lock the Expansion Card into its slot.
      • Locking the Expansion Card slots help keep the cards in place when you unplug cables from them.
      Спросите у FixBot
    5. Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: шаг 5, изображение 1 из 3 Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: шаг 5, изображение 2 из 3 Framework Laptop 12 Pre-built Quick Start Guide, Assemble the Framework Power Adapter: шаг 5, изображение 3 из 3
      • Plug the AC Cable into the Power Adapter.
      • Plug the USB-C Cable into the Power Adapter.
      • You can plug either end of the USB-C cable into the adapter.
      • Plug the AC Cable into a power outlet.
      Спросите у FixBot
    6. Framework Laptop 12 Pre-built Quick Start Guide, Plug in the laptop: шаг 6, изображение 1 из 1
      • Your Framework Laptop ships in shipping mode, where the battery is disabled until you plug the laptop in for the first time.
      • Plug the USB-C cable into any USB-C port on your laptop.
      Спросите у FixBot
    7. Framework Laptop 12 Pre-built Quick Start Guide, Turn on the laptop: шаг 7, изображение 1 из 1
      • Your Framework Laptop is ready for use! Open the lid and press the power button along the right edge of the laptop.
      Спросите у FixBot
Заключение
For drivers, firmware, and software updates, check out this page.
If you need help, contact Framework support.
Arthur Shi
Участник с: 01/03/18
344 562 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 42 323 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 20
За всё время: 496
