Galaxy Note10 Plus Loudspeaker Replacement
Выберете то, что вам нужно
  1. Galaxy Note10 Plus Loudspeaker Replacement, Heat the rear cover: шаг 1, изображение 1 из 1
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Galaxy Note10 Plus Loudspeaker Replacement, Insert an opening pick: шаг 2, изображение 1 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Insert an opening pick: шаг 2, изображение 2 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Insert an opening pick: шаг 2, изображение 3 из 3
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Galaxy Note10 Plus Loudspeaker Replacement, Begin to slice the adhesive: шаг 3, изображение 1 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Begin to slice the adhesive: шаг 3, изображение 2 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Begin to slice the adhesive: шаг 3, изображение 3 из 3
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Galaxy Note10 Plus Loudspeaker Replacement, Slice around the perimeter of the phone: шаг 4, изображение 1 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Slice around the perimeter of the phone: шаг 4, изображение 2 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Slice around the perimeter of the phone: шаг 4, изображение 3 из 3
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
  5. Galaxy Note10 Plus Loudspeaker Replacement, Lift off the rear cover: шаг 5, изображение 1 из 2 Galaxy Note10 Plus Loudspeaker Replacement, Lift off the rear cover: шаг 5, изображение 2 из 2
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
  6. Galaxy Note10 Plus Loudspeaker Replacement, Lift up the metal cover: шаг 6, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  7. Galaxy Note10 Plus Loudspeaker Replacement: шаг 7, изображение 1 из 3 Galaxy Note10 Plus Loudspeaker Replacement: шаг 7, изображение 2 из 3 Galaxy Note10 Plus Loudspeaker Replacement: шаг 7, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  8. Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the battery: шаг 8, изображение 1 из 2 Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the battery: шаг 8, изображение 2 из 2
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  9. Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the wireless charging coil: шаг 9, изображение 1 из 2 Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the wireless charging coil: шаг 9, изображение 2 из 2
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  10. Galaxy Note10 Plus Loudspeaker Replacement, Remove the wireless charging coil: шаг 10, изображение 1 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Remove the wireless charging coil: шаг 10, изображение 2 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Remove the wireless charging coil: шаг 10, изображение 3 из 3
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
  11. Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker screws: шаг 11, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
  12. Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker: шаг 12, изображение 1 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker: шаг 12, изображение 2 из 3 Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker: шаг 12, изображение 3 из 3
    • Use a pair of tweezers to remove the loudspeaker.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
4 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
158 908 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
124 членов
Автор 24 149 руководств
1 Комментарий к руководству
Grazie per la guida, ho sostituito l'altoparlante e il cellulare è come nuovo
Roberto Di Santolo - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 54
За всё время: 3,548
