Garmin DriveSmart 55 EX Battery Replacement
Выберете то, что вам нужно
  1. Garmin DriveSmart 55 EX Battery Replacement, Battery: шаг 1, изображение 1 из 3 Garmin DriveSmart 55 EX Battery Replacement, Battery: шаг 1, изображение 2 из 3 Garmin DriveSmart 55 EX Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    Спросите у FixBot
    Добавить комментарий
  2. Garmin DriveSmart 55 EX Battery Replacement: шаг 2, изображение 1 из 3 Garmin DriveSmart 55 EX Battery Replacement: шаг 2, изображение 2 из 3 Garmin DriveSmart 55 EX Battery Replacement: шаг 2, изображение 3 из 3
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    Спросите у FixBot
  3. Garmin DriveSmart 55 EX Battery Replacement: шаг 3, изображение 1 из 3 Garmin DriveSmart 55 EX Battery Replacement: шаг 3, изображение 2 из 3 Garmin DriveSmart 55 EX Battery Replacement: шаг 3, изображение 3 из 3
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    • Gently remove the battery from the casing.
    • If you're unable to get a grip on it, use the opening tool to lift it enough to get your fingers underneath.
    • Avoid bending or puncturing the battery as it can catch fire.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Jacob Behnke
Участник с: 03/11/26
707 Репутация
Автор 4 руководств
Команда
Purdue University Northwest, Team 7-1, Dieterle Spring 2026 Участник Purdue University Northwest, Team 7-1, Dieterle Spring 2026
PNW-DIETERLE-S26S7G1
3 членов
Автор 8 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 13
За последние 30 дней: 40
За всё время: 176
